[GRASS5] NVIZ .. did a #if in tkUnixPort.h ... Is this a bad?
Markus Neteler
neteler at geog.uni-hannover.de
Thu Oct 19 06:53:05 EDT 2000
On Wed, Oct 18, 2000 at 11:03:54PM -0700, Eric G . Miller wrote:
> Hey all,
> After doing a full clean, I still couldn't get NVIZ to compile. By
> adding a '#if (TCL_MINOR_VERSION) < 2' wrapper around the declaration of
> 'extern panic(...)' I got it to compile and run finally. I probably
> should've asked here before committing this change, but will this be a
> problem? Seems there's no way to put "sensitivity" into togl.h, since
> the file is include by the system tk.h, for which there is no local
> copy. Don't know if there's a better solution, but I do know this is
> where at least one compile problem is coming from.
Hi Eric,
here (Suse 7, tcl/tk8.3) it still compiles fine.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
