[GRASS5] NVIZ problem
Eric G . Miller egm2 at jps.net
Tue Oct 17 11:16:23 EDT 2000
On Tue, Oct 17, 2000 at 03:22:25PM +0700, Justin Hickey wrote:
> Hello Markus
> Markus Neteler wrote:
> > still one of the famous GRASS modules does not compile any more...
> > Bob Covill fixed the core dump problem of NVIZ, but
> > it cannot be compiled because of this strange ID_matrix
> > double definition. I just can't see it!
> > Suggestions would be very welcome.
> I'm not sure if you tried this yet, but I would try a fresh CVS checkout
> and then try to compile, preferably on a machine that never had grass
> installed before. The error still doesn't make any sense to me. Has any
> other Linux user seen the same problem?
> For what it's worth, NVIZ compiled on our SGI origin and it seems to run
> fine (I only loaded a map and displayed it).
I haven't been able to compile for around two weeks. Errors:
gcc -g -O2  -I/usr/X11R6/include -I/usr/include/tcl8.3 -I/usr/include
-I/usr/local/src/grass/src/libes/ogsf  -D_NO_PROTO -D__STDC__
-I/usr/include/postgresql -I/usr/local/src/grass/src/include  -c
nvizAppInit.c -o OBJ.i686-pc-linux-gnu/nvizAppInit.o
In file included from tkPort.h:34,
                 from tkInt8.3.h:27,
                 from togl.h:21,
                 from nvizAppInit.c:8:
tkUnixPort.h:185: conflicting types for `Tcl_Panic'
/usr/include/tcl8.3/tclDecls.h:38: previous declaration of `Tcl_Panic'
make[1]: *** [OBJ.i686-pc-linux-gnu/nvizAppInit.o] Error 1
make[1]: Leaving directory
`/usr/local/src/grass/src.contrib/GMSL/NVIZ2.2/src'
make: *** [nvwish] Error 2
Funny, I don't even see -I/usr/include/tk8.3, should I?
/bin/sh ~/.signature:
Command not found
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
