[GRASS5] CVS - grass compilation on linux and IRIX
Andreas Lange
Andreas.Lange at Rhein-Main.de
Fri Oct 13 14:07:45 EDT 2000
Hi Justin, Hi Markus,
thank you very much for the change.
The main reason for this wish was that i had no running grass session
when i had to do a cleanup to test if the changes in the CVS work. But
after recompiling i didn't had a new installation either. Next time i'll
copy the binary tree.
I think that the grass compiling system does not really conform to GNU
standards so that a additional target would not hurt.
The paths on IRIX are as follows from the head file i send attached.
Although the /usr/lib32, /usr/freeware/lib32 etc paths are not standard
outside the IRIX world, they are standard for IRIX and other GNU
software compiles without changes. The location for the tcl/tk libraries
may be different on other machines. I did not check if all modules work.
Next for the modules not compiling (see error.log attached). Some of the
modules do not compile on linux and IRIX. Just to inform you.
cu,
Andreas
Justin Hickey wrote:
> Markus Neteler wrote:
> > On Fri, Oct 13, 2000 at 02:51:56PM +0700, Justin Hickey wrote:
> > > I will create a new target named savebinclean that will remove all
> > > object files, the libraries, and the files created by configure. Any
> > > objections to this new target?
> > Well, I think more targets are better than less. If we meet the
> > GNU standards as subset with additional targets, everyboday should
> > be happy.
> OK I will commit the change now.
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
CC = gcc
FC = g77
LEX = flex
YACC = yacc
ARCH = mips-sgi-irix6.5
MAKE = make
GISBASE = /usr/local/grass-5.0b
UNIX_BIN = /usr/local/bin
DEFAULT_DATABASE =
DEFAULT_LOCATION =
COMPILE_FLAGS = -g -O2
LDFLAGS =
DLLIB = -ldl
XCFLAGS = -I/usr/X11R6/include
# XXX - replace SYSV in code with configure results in config.h
# XXX - need SYSV defined for hpux10
XLDFLAGS =
XINCPATH =
XMINCPATH =
XLIBPATH = -L/usr/X11R6/lib
XTLIBPATH =
XMLIBPATH =
XLIB = -lSM -lICE -lX11
XTLIB = -lXt
XMLIB = -lXm
XEXTRALIBS =
COMPATLIB =
TERMLIB =
CURSES = -lncurses $(TERMLIB) $(COMPATLIB)
MATHLIB = -lm
XDRLIB = -lnsl
#PostgreSQL:
PQINCPATH =
PQLIBPATH =
PQLIB =
#ODBC:
ODBCINC = NO
#Image formats:
PNGINC = -I/usr/X11R6/include/ -I/usr/freeware/include -I/usr/local/include -I/usr/include
PNGLIB = -L/usr/freeware/lib32 -L/usr/X11R6/lib -L/usr/lib32
JPEGINCPATH = -I/usr/X11R6/include/ -I/usr/freeware/include -I/usr/local/include -I/usr/include
JPEGLIBPATH = -L/usr/freeware/lib32 -L/usr/X11R6/lib -L/usr/lib32
TIFFINCPATH = -I/usr/freeware/include -I/usr/include
TIFFLIBPATH = -L/usr/freeware/lib32 -L/usr/lib32
#openGL files for NVIZ/r3.showdspf
OPENGLINC = -I/usr/include/GL
OPENGLwINC = -I/usr/include/GL
OPENGLLIB = -L/usr/lib32/libGL.so
OPENGLULIB = -L/usr/lib32/libGLU.so
LGLWM =
#tcl/tk stuff
TCLINCDIR = -I/usr/freeware/include
TKINCDIR = -I/usr/freeware/include
TCLTKLIBS = -L/usr/freeware/lib32
LIBRULE = ar ruv $@ $?; ranlib $@
USE_TERMIO =
Compilation error in module: src/mapdev/v.digit (ignored)
Compilation error in module: src/raster/r.in.dem (ignored)
Module source code not installed: src/raster/r.in.gdal (ignored)
Module source code not installed: src/raster/r.in.gridatb (ignored)
Compilation error in module: src/raster/r.in.png (ignored)
Module source code not installed: src/raster/r.out.gridatb (ignored)
Compilation error in module: src/raster/r.out.png (ignored)
Module source code not installed: src/raster/r.proj.new (ignored)
Module source code not installed: src/raster/r.topidx (ignored)
Module source code not installed: src/raster/r.topmodel (ignored)
Compilation error in module: src/scripts (ignored)
Compilation error in module: src.contrib/GMSL/NVIZ2.2 (ignored)
