[GRASS5] Linux KDE: GRASS monitor does not refresh
Markus Neteler
neteler at geog.uni-hannover.de
Fri Oct 13 13:18:37 EDT 2000
Roberto,
thanks!! I got it like that:
On Fri, Oct 13, 2000 at 04:19:53PM +0200, Roberto Micarelli wrote:
> Markus Neteler wrote:
> > Hi all,
> > recently I switched to KDE 1.1.2 (SuSe 7) and have the problem,
> > than the GRASS monitor does not refresh if hidden by another window
> > and put back into foreground. It remains black.
> > Does anyone have an idea how to fix this?
> > Thanks!
> > Markus
> It seems exposure events not being generated.
> One trivial way could be to enable backing-store in the X server
> (more memory needed by X)
> In /etc/X11/xdm/Xserver
> change a line like this
> :0 local /usr/X11R6/bin/X
> to
> :0 local /usr/X11R6/bin/X -wm
The "backing-store" thing was the right idea. I had to
add
Option "backingstore" "on"
to the
Section "Device"
of /etc/X11/XF86Config as I am using Xfree4. Now it works o.k.
Thanks a lot
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
