[GRASS5] Display bug with tcltkgrass
Andreas Lange
Andreas.Lange at Rhein-Main.de
Fri Oct 13 13:53:11 EDT 2000
another hint: You can tear-off menues you are using frequently by
clicking on the dotted line at the top of the menue.
I personally think that a vertical menue (like the toolbar in the GIMP)
would be better (consider the monitor ratio!), perhaps with icons
instead of txt?
If someone has ideas about this please tell the list.
cu,
Andreas
Eric G . Miller wrote:
> On Thu, Oct 12, 2000 at 06:51:16AM -0500, Tim Cera wrote:
> > On my laptop, the tcltkgrass menu does not display fully. I can only
> > see the 'ui' of the 'Quit' command and the sub-menus that pop-up to the
> > side do not display properly for those menu choices on the right side of
> > the menu bar.
> Try changing the fonts. The command is on the left side. But, given the
> width of the menu bar, perhaps it should be split?
> /bin/sh ~/.signature:
> Command not found
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
