[GRASS5] Re: CVS update: grass/src/general/init
Justin Hickey
jhickey at hpcc.nectec.or.th
Thu Oct 12 01:05:51 EDT 2000
Hello Huidae
grass at intevation.de wrote:
> Date: Wednesday October 11, 2000 @ 16:20
> Author: cho
> Update of /grassrepository/grass/src/general/init
> In directory intevation.de:/tmp/cvs-serv8316
> Modified Files:
> Gmakefile
> Log Message:
> create $(BIN)/grass5 shell first then
> if $(UNIX_BIN)/grass5 exists and writeable copy $(BIN)/grass5 to
> $(UNIX_BIN)/grass5.
> This process is useful for non-root GRASS install. Only $(BIN) is
> required to be writeable.
This change has caused a crash on my system. Here is the error message
that was reported.
GISGEN: src/general/init - Thu Oct 12 11:50:49 TST 2000
/usr1/grass/grass64/grass/src/general/init
mkdir OBJ.mips-sgi-irix6.5
make -f OBJ.mips-sgi-irix6.5/make.rules
/usr1/grass/grass64/grass/bin/grass5 not found
*** Error code 1 (bu21)
GISGEN failure at STEP: src/general/init
Please check your changes. This module compiled fine for me before. I'm
not sure what the problem is but my definitions of BIN and UNIX_BIN are
as follows (if this helps)
BIN = /usr1/grass/grass64/grass/bin
UNIX_BIN = /usr1/grass/grass64/grass/bin
As you can see they are the same.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
