[GRASS5] sites problem/bug?
Andreas Lange Andreas.Lange at Rhein-Main.de
Sun Oct 8 09:18:18 EDT 2000
i have a problem with a sites file. I can import the file with grass4.3
(and export and display it) with s.in.ascii, s.out.ascii and d.sites,
but on grass 5.0 i get on importing or exporting a "WARNING: error
scanning floating point attribute" and the resulting sites file is
empty.
The format is e. g.:
16.00000 45.800000 "String"
-1.05000 41.667000 "String"
If i import with grass4.3 or write the format with the "|" separator
myself with a perl program, s.out.ascii and d.sites work within
grass5.0beta.
I am getting mad about those inconsistencies with the sites format. I
consider this as a very annoying bug, but if someone knows a workaround,
please tell me.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
