[GRASS5] Re: CVS update: grass/src/mapdev/v.digit
Markus Neteler neteler at geog.uni-hannover.de
Mon Oct 9 14:14:45 EDT 2000
On Mon, Oct 09, 2000 at 07:24:13PM +0200, grass at intevation.de wrote:
> Date:	Monday October 9, 2000 @ 17:24
> Author:	cho
> Update of /grassrepository/grass/src/mapdev/v.digit
> In directory intevation.de:/tmp/cvs-serv27710
> Modified Files:
> 	label_mult.c
> Log Message:
> modified "Label/UnLabel Multiple Lines" menu to click once to perform.
> To label or unlabel multiple lines, two confirmations, selecting line and
> do labelling/unlabelling, were needed before.
> Now select confirmation means also doit confirmation.
> In TODO, selecting all wanted lines then confirmation was told, however
> confirmation also needed when selecting each line.  This can be doit
> confirmation.
> '#define CONFIRM' is needed for doit confirmation.
Hi Huidae Cho,
sounds good! Thank for implementing this wish!
What do you think: is it feasible to implement an undo
function? As the vectors are only tagged to be deleted
it might be possible. Just another idea...
Kind regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
