[GRASS5] NVIZ+legends
Markus Neteler
neteler at geog.uni-hannover.de
Mon Oct 9 03:54:17 EDT 2000
On Sat, Oct 07, 2000 at 10:30:33PM -0500, Helena Mitasova - staff wrote:
> Prasad,
> I have switched to LINUX recently and quickly discovered
> as you did that there is absolutely no reasonable way
> to create a legend in GRASS without SG3d which makes
> GRASS a pretty bad tool for working with spatial data
> when you cannot explain what you have in your image.
> I talked to Bill about the legends already -
> Bill is on this list too - Bill did you have a chance
> to look at the possibility to port the legends from
> SG3d to NVIZ? Are there any seroius obstacles to do that?
> Would it be possible for the developer of d.dm to
> add the legend tool there too?
> >d.legend needs to be updated....there is no facility to place the legend
> >exactly on the screen and also control the size of the text and boxes
> this was to great extend available in sg3d, including the
> user defined intervals, etc., but it is not available in NVIZ
> or for any other display tool (as far as I know)
> >2. For categorical maps with more than 10 classes, where user
> >discrimination
> >among colors becomes difficult, there should be a flash utility. Based on
> >d.legend ... we should be able to click on any legend box and have the
> >corresponding class flash on the map (on-off sequence with user defined
> >color).
> This would be very useful too.
> If anybody has time and ability to do something
> about legends you can find more details about the legend at
> http://www2.gis.uiuc.edu:2280/modviz/appdoc/sg3d42.html
> and it may be possible to use some of the code used in SG3d.
> Markus - aren't you missing the legends too?
Yes, desperately...
You are right: Legends are one of the big problems of GRASS
additionally to map printing as it is difficult to tell people
nowadays that they should use ps.map.
Your SG3d/SG4d modules are looking impressive, unfortunately
I don't have an SGI. So it would be great to merge the legend
code into NVIZ.
Hoping the best
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
