[GRASS5] Re: [NVIZ] Code for PPM dumps
Markus Neteler
neteler at geog.uni-hannover.de
Wed Sep 27 11:16:44 EDT 2000
On Tue, Sep 26, 2000 at 12:56:48PM +0200, Andreas Lange wrote:
> Markus,
> the big endian/little endian part of the code will give problems, as not
> only sun machines are big-endian. There are more general solutions, have
> a look at tifflib. There must be other code within grass where this
> problem is solved, but i have currently no time to search. I don't know
> exactly if a config-solution or a solution within the code is better,
> cu,
Hi Andreas,
you are right. Here is the extracted test from libtiff:
CheckForBigEndian()
echo 'main() { int one = 1; char* cp = (char*)&one; exit(*cp!=0); }'>t.c
capture cat t.c
runMake t "t:; ${CCOMPILER} ${ENVOPTS} t.c" && ./a.out
if CheckForBigEndian; then
echo "#define HOST_BIGENDIAN 1"
Note "... using big-endian byte order for your $CPU cpu"
else
echo "#define HOST_BIGENDIAN 0"
Note "... using little-endian byte order for your $CPU cpu"
fi
It should be written to config.h.
Does anyone know how to implement this test into current "configure"?
Thanks
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
