[GRASS5] CRAY T3E compile errors
Markus Neteler
neteler at geog.uni-hannover.de
Fri Sep 22 11:54:23 EDT 2000
Hi all,
excuse me for writing so many mails...
As I am still not very experienced with fixing pointer problems,
I would like to ask for assistance with further CRAY compile
errors (the other errors from my previous mail are fixed):
Further CRAY T3E compile errors:
/home/t3e/fsn/nhdc/nhdcmark/grass/src/mapdev/v.cutter
make -f OBJ.alpha-cray-unicosmk2.0.4.X/make.rules
cc -g -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c build.c
-o OBJ.alpha-cray-unicosmk2.0.4.X/build.o
CC-167 cc: ERROR File = build.c, Line = 313
Argument of type "struct poly_vert_info **" is incompatible with parameter
of
type "void **".
swap_pointers (&Vert, &Vert2);
of
type "void **".
2 errors detected in the compilation of "build.c".
Make: "cc -g -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c build.c
-o OBJ.alpha-cray-unicosmk2.0.4.X/build.o": Error code 1
cmd-2436 make: Stop.
/home/t3e/fsn/nhdc/nhdcmark/grass/src/mapdev/v.in.shape
dbutils.c -o OBJ.alpha-cray-unicosmk2.0.4.X/dbutils.o
CC-167 cc: ERROR File = dbutils.c, Line = 93
Argument of type "pntDescript ***" is incompatible with parameter of type
"void **".
res = btree_find( hDB, keyHolder, &dataHolder );
1 error detected in the compilation of "dbutils.c".
Make: "cc -g -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c dbutils.c
-o OBJ.alpha-cray-unicosmk2.0.4.X/dbutils.o": Error code 1
/home/t3e/fsn/nhdc/nhdcmark/grass/src/mapdev/v.out.mif
cc -g -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c plot.c
-o OBJ.alpha-cray-unicosmk2.0.4.X/plot.o
CC-167 cc: ERROR File = plot.c, Line = 109
Argument of type "struct Map_info **" is incompatible with parameter of
type
"struct Map_info *".
Vect_close (&Map);
CC-167 cc: ERROR File = plot.c, Line = 139
type
Vect_close (&Map);
2 errors detected in the compilation of "plot.c".
Make: "cc -g -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c plot.c -o
OBJ.alpha-cray-unicosmk2.0.4.X/plot.o": Error code 1
/home/t3e/fsn/nhdc/nhdcmark/grass/src/mapdev/v.rmdup/cmd
cc -g -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c rmdup.c
-o OBJ.alpha-cray-unicosmk2.0.4.X/rmdup.o
CC-136 cc: ERROR File = rmdup.c, Line = 198
The struct "<unnamed>" has no field "_shortbuf".
while (match == 0 && Closet->dig_fp->_shortbuf[1]) /* try to upgrade
in 5/2000 */
1 error detected in the compilation of "rmdup.c".
Make: "cc -g -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c rmdup.c
-o OBJ.alpha-cray-unicosmk2.0.4.X/rmdup.o": Error code 1
Make: "/home/t3e/fsn/nhdc/nhdcmark/grass5bin/gmake5 cmd": Error code 1
/home/t3e/fsn/nhdc/nhdcmark/grass/src/raster/r.binfer
rm -f lex.c gram.c
yacc binfer.y
rm -f gram.c
mv y.tab.c gram.c
cc -g -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c gram.c
-o OBJ.alpha-cray-unicosmk2.0.4.X/gram.o
lex binfer.l
"binfer.l":line 13: Error: Missing translation value
Make: "lex binfer.l": Error code 1
-> looks like a problem with "%option lex-compat"
Many thanks
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
