[GRASS5] Revised^2 Code Freeze schedule
Frank Warmerdam
warmerda at home.com
Fri Sep 22 10:42:38 EDT 2000
Markus Neteler wrote:
> 3) replace GRASS i/o routines by "libgrass" (Frank Warmerdam)
Markus,
It isn't clear to me that it is desirable for GRASS to directly use
libgrass. Instead I would state the following objectives.
o While restructing the build environment and source tree consider
our options to build various component libraries as shared libraries
to reduce the size of resulting command executables.
o Migrate some (or all?) of the extended APIs in libgrass back into
libgis.
Also, on the 3D vectors. A change of vector format is a big change. While
it might be doable by 5.1, I don't think it is a forgone conclusion that it
could or should be. A vector/DBMS overhaul might instead be what defines
a GRASS 6.0. Is this one of the areas that Baylor has been experimenting?
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerda at home.com
light and sound - activate the windows | http://members.home.com/warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
