[GRASS5] Code Freeze schedule
Markus Neteler neteler at geog.uni-hannover.de
Fri Sep 22 06:40:40 EDT 2000
On Fri, Sep 22, 2000 at 10:46:28AM +0200, Michel Wurtz wrote:
> Markus Neteler a écrit :
> > believe that I am far from putting pressure on you! But I think
> > that a graphical login to GRASS 5 is very important. So it would
> I will like a graphical login, but there should also be a command-line login :
> sometimes, you just want to run some long command or run batches (with the
> unix "at" command) in background.  This work well because "at" takes care of
> environment variables, so you can run some time consuming computation while
> you sleep (or watch olympic games at home in your armchair :-). I think you
> have to take care of that in the design of a new login interface...
Justin will take care of this (certainly the script login will be kept!)
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
