[GRASS5] Bugreport GRASS 5
timcera at earthlink.net timcera at earthlink.net
Wed Sep 20 23:38:39 EDT 2000
Below is the result of your feedback form.  It was submitted by
 (timcera at earthlink.net) on Thursday, September 21, 2000 at 04:38:39
subject: Bugreport GRASS 5
platform: Linux/Intel
vendor: SuSe
cputype: AMD (K6, ...)
grassversion: I compiled the sources myself
cvsyesno: yes, I am using the latest GRASS from CVS
module: r.rescale
bugreport: The command
> r.rescale input=asp1 from=0,180 output=test_north to=1,1
r.rescale does not set cells outside the "from" range to 0 (described in the help), but to null
compiler: gcc
compiler_version: 2.95.2
REMOTE_HOST: sdn-ar-001flgainp001.dialsprint.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
