[GRASS5] Code Freeze schedule
David D Gray
ddgray at armadce.demon.co.uk
Wed Sep 20 15:59:49 EDT 2000
Markus
This schedule is OK by me.
David
Markus Neteler wrote:
> Hi all,
> after receiving another request for code freeze to finalize
> the GRASS 5 stable I want to propose a schedule (with your
> assistance):
> Things which should go into GRASS 5.0 stable
> - new "init" mechanism (Justin Hickey)
> - new env variable management (Justin Hickey)
> - new autoconf (Eric Mitchell)
> - Datum support for projections (Andreas Lange)
> - sockets Xdriver (Carl Anderson)
> - extent the test-suite testgrass.sh (all)
> -> is this realistic?: please correct me, if not
> Things which should go into GRASS 5.1 development
> - code restructuring to packages (requires autoconf)
> - 3D vectors (David D Gray, Radim Blazek)
> - probably replace GRASS i/o routines by "libgrass" (Frank Warmerdam)
> - layered XDRIVER (Pierre de Mouveaux)
> - full RGB support in all display modules (Pierre de Mouveaux)
> - tons of other stuff
> Timeline:
> - 1. Oct. 2000: Code freeze, split into stable tree and development tree
> - start bugfixing only on stable tree, *concentrate* on bugfixes
> - exeptional continue meanwhile on development team
> - xx.xx.2000: Publish GRASS 5.0stable
> What's missing? Any other suggestions? Is code freeze at Oct. 1 too
> early/late?
> Awaiting your comments
> Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
