[GRASS5] readsites() TODO list...
Eric G . Miller
egm2 at jps.net
Wed Sep 20 06:09:24 EDT 2000
A week or so ago, I looked at the TODO list and thought I'd look into
this readsite() library function. I arrived at the conclusion that the
call would have to be different to support reading z-dim, double-att, or
strtod(string-att), for generating an *xyz struct. Anyway, I already
did one iteration that added support for the z-dim, but I wanted to put
up this call interface for comments. We could make it a readsites2()
and retain the other interface for awhile. I don't know how many
modules actually use readsites() at the moment. Anyway, please let me
know if the behaviors described here look awful (I'm still new to coding
for GRASS).
/* readsites: Reads a sites file converting to a site struct of xyz values.
* The Z value can come from one of the z-dimensions, a double attribute,
* or a string attribute converted to a double with strtod().
* If 'num' is less than one, attempt to read entire site file, otherwise
* read 'num' records. The number of records read is returned. If an
* error occurs, a negative value is returned. The caller can decide to
* abort or retry. Error values are:
* Couldn't allocate memory -1
* Attribute 'type' not found -2
* Attribute 'index' out of range -3
* Format error in file (includes conversion error) -4
* Something else (probably never happen) -5
typedef struct _site {
double x, y, z;
} site;
int readsites(
FILE * fdsite, /* The FILE stream to the sites file */
int num, /* Number of records to read */
int type, /* Attribute type: 0 = Z-dim, 1 = double, 2 = string */
int index, /* The field index (1 based) for the attribute */
int * done, /* No more records in file? 0 = false, 1 = true */
site **xyz /* The site array, caller must free between calls */
/bin/sh ~/.signature:
Command not found
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000920/6bcca61a/attachment.bin
