[GRASS5] CRAY T3E compile errors
Bernhard Reiter bernhard at intevation.de
Tue Sep 19 11:36:00 EDT 2000
On Tue, Sep 19, 2000 at 04:56:59PM +0100, Markus Neteler wrote:
> currently I have access to a CRAY T3E in our university computer
> center and try to compile the GRASS (what surprise).
> I have to use a CC compiler:
> cc(1) and c89(1).  These commands invoke the Cray Standard C
>        compiler and the source preprocessor on source files that contain C
>        code.  The compiler conforms to the International Standards
>        Organization (ISO) ISO/IEC 9899:1990 and to the American National
>        Standards Institute (ANSI) X3.159-1989 standards.  The c89 command
>        conforms to the POSIX standard, IEEE Std P1003.2.
Even when compatible with C standards,
there can be significant differences.
> Unfortunately I run into some troubles where I am rather
> helpless:
> /home/t3e/fsn/nhdc/nhdcmark/grass5/src/libes/digitizer
> sh-48 /home/t3e/fsn/nhdc/nhdcmark/grass5bin/gmake5[7]:
> OBJ.alpha-cray-unicosmk2.0.4.X/make.rules: file already exists.
>   make -f OBJ.alpha-cray-unicosmk2.0.4.X/make.rules
> cmd-2415 make: line '158': 'syntax error'. Stop.
> Make: "/home/t3e/fsn/nhdc/nhdcmark/grass5bin/gmake5 digitizer": Error code 1
> -> I can't see any problems in libes/digitizer/OBJ*/make.rules
>    But somehow it is different to other make.rules files?!
What version of make are you using?
(It might be an idea to build gnu make first.)
> CC-140 cc: ERROR File = fork.c, Line = 32
>   Too many arguments in function call.
>         setpgrp (0, getpid());
> 1 error detected in the compilation of "fork.c".
> Make: "cc -g   -I/home/t3e/fsn/nhdc/nhdcmark/grass5/src/include  -c fork.c
> -o OBJ.alpha-cray-unicosmk2.0.4.X/fork.o": Error code 1
> cmd-2436 make: Stop.
> Make: "/home/t3e/fsn/nhdc/nhdcmark/grass5bin/gmake5 gis": Error code 1
> -> mhhh, no idea here
Try "man setpgrp" and compare.
> /home/t3e/fsn/nhdc/nhdcmark/grass5/src/libes/proj
>         rm -f OBJ.alpha-cray-unicosmk2.0.4.X/bch2bps.o
>         cc -g  -I. -I/home/t3e/fsn/nhdc/nhdcmark/grass5/src/include  -c
> bch2bps.c
> CC-167 cc: ERROR File = bch2bps.c, Line = 141
>   Argument of type "UV **" is incompatible with parameter of type "void **".
>         freev2(d, nu);
> 1 error detected in the compilation of "bch2bps.c".
> Make: "cc -g  -I. -I/home/t3e/fsn/nhdc/nhdcmark/grass5/src/include  -c
> bch2bps.c": Error code 1
> Make: "/home/t3e/fsn/nhdc/nhdcmark/grass5bin/gmake5 proj": Error code 1
Again, man might help.
You might be able lto use a cast here.
Professional Service around Free Software                (intevation.net)
The FreeGIS Project				            (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000919/c02193cb/attachment.bin
