[GRASS5] Postgresql and Grass
Eric G . Miller
egm2 at jps.net
Fri Sep 15 16:33:02 EDT 2000
On Fri, Sep 15, 2000 at 01:47:26PM -0600, John Huddleston wrote:
> ----- Original Message -----
> From: Rich Shepard <rshepard at appl-ecosys.com>
> To: <grass5 at geog.uni-hannover.de>
> Sent: Friday, September 15, 2000 7:53 AM
> Subject: Re: [GRASS5] Postgresql and Grass
> <snip>
> > A multiple-table (probably relational) design is needed because not all
> > attributes of a single object should (can?) be stored in one table. Soils
> > data, for example.
> <snip>
> I am familiar with the USDA NRCS soils database. Recently,
> I coverted their schema to an Xml DTD schema. They are
> going to post data to their users in both Access MDB format
> as well as Xml format.
Is that a DTD or an XML Schema? The new XML Schema standard looks like
a better way than SGML/XML DTD's. It has better typing and pattern
matching constraints, to name a couple features. These are the kinds of
things needed for databases. It's pretty new, so there aren't many
tools to use it yet ;(
> Going with a proprietary format makes software solutions
> unattainable for those monetarily challenged. Plus, software
> becomes obsolete (like Access). SQL server, Informix,
> and Oracle are a large overhead. mySQL is low overhead;
> however there is one other consideration...
> The flat ASCII file format has the benefit of being portable.
> If the meta data files are reasonably small, there is no large
> performance penalty for reading them. Moving to an Xml
> based format is a reasonable alternative IMHO.
Still, for any reasonably large database some kind of indexing scheme is
necessary for performance. Typing metadata is also desirable. As a
note: the preferred standard for XML is Unicode (get those high
characters). I'm sure all our European friends would appreciate not
limiting to ASCII.
> I would be willing to assist in this direction.
Yes, I like this too.
/bin/sh ~/.signature:
Command not found
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
