[GRASS5] Thought on my CVS problem
Bernhard Reiter bernhard at intevation.de
Wed Sep 13 04:06:28 EDT 2000
On Wed, Sep 13, 2000 at 12:55:49AM -0700, Eric G . Miller wrote:
> On Wed, Sep 13, 2000 at 08:58:39AM +0200, Bernhard Reiter wrote:
> > > This is normal practice in other projects.
> > > Further, the files named should be included in a .cvsignore file in
> > > the directory that they will reside, and the .cvsignore files should be
> > > in CVS.
> > This only helps with imports, right?
> It'll keep all "ignored" file from being added to repository. Makefiles,
> object files, etc. are all good candidates. You can use wildcards in the
> file *.o, OBJ_*, etc...
Yes.
But this only matters when doing a recursive cvs import.
	Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project				            (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000913/b2f25c84/attachment.bin
