[GRASS5] Thought on my CVS problem
Eric G . Miller egm2 at jps.net
Wed Sep 13 03:55:49 EDT 2000
On Wed, Sep 13, 2000 at 08:58:39AM +0200, Bernhard Reiter wrote:
> > This is normal practice in other projects.
> > Further, the files named should be included in a .cvsignore file in
> > the directory that they will reside, and the .cvsignore files should be
> > in CVS.
> This only helps with imports, right?
It'll keep all "ignored" file from being added to repository. Makefiles,
object files, etc. are all good candidates. You can use wildcards in the
file *.o, OBJ_*, etc...
/bin/sh ~/.signature:
Command not found
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
