[GRASS5] Formatting and wording of copyright and license
Bernhard Reiter
bernhard at intevation.de
Wed Sep 13 04:00:58 EDT 2000
Minor glitches with the top copyright and license files.
I will correct them, if nobody has objections.
* Text files should be formatted in 80 columns for reading pleasure.
GPL.TXT is not, so I will put in the plan text version with fsf
original 80 columns formatting.
AUTHORS needs some manual formatting.
* COPYRIGHT could be improved slightly:
My plan is to replace the paragraph:
"Individual copyrights upheld by original authors and not
superceded by the GRASS GPL Copyright. Users must abide by applicable
copyrights for individual programs where noted."
with:
"Parts of GRASS are not copyright by the GRASS development team.
The original authors hold the copyright and you have to abide
to their licensing terms where noted."
I could also add a clarification sentence:
"(Keep in mind that code linking into GRASS can only be
distributed if compatible with the GPL.)"
For redundancy we should also add the Hannover
Internet addess the file.
Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000913/cee8779b/attachment.bin
