[GRASS5] Thought on my CVS problem
Bernhard Reiter
bernhard at intevation.de
Wed Sep 13 04:04:45 EDT 2000
On Wed, Sep 13, 2000 at 02:50:28PM +0700, Justin Hickey wrote:
> Bernhard Reiter wrote:
> > On Wed, Sep 13, 2000 at 08:26:02AM +1100, James Cameron wrote:
> > > Yes, I agree that the compilation or configure output files should
> > > be removed from the CVS tree.
> > I also agree,
> > but we must have them in the tarball,
> > so there should be a target to just build them if we remove them from
> > the CVS version.
> > Not everybody has a recent autoconf or flex/bison installed and
> > properly configured. Which means we are excluding some people from
> > using the
> > CVS directly. (I do not think it is a problem, but it should be
> > noted.)
> But these files are platform dependent (especially the autoconf files).
configure should not be platform dependent.
Most free software packages coming with a ready to run configure
and lex and yacc output files.
So you can compile without proper automake/autoconf installed.
But you need this as a developer if you want to create configure.
Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000913/084ef965/attachment.bin
