[GRASS5] Proposal for a new GRASS directory structure
Eric Mitchell
emitchell at altaira.com
Tue Sep 12 10:17:49 EDT 2000
Bernhard Reiter wrote:
> Yes, grass-base and then thematic packages would be nice.
> nviz is 3D and even has other requirements (OpenGL/Mesa).
What other thematic packages would make sense? I'm not
really a GIS whiz, I just like making maps of places I've
hauled my consumer grade GPS receiver with me. =) The
trick is acheiving a reasonable balance between one source
tarball with everything, and one source module for each
binary. I'm not sure where to draw a reasonable lines
between those two extremes.
> > My recommendation
> > for dealing with the reorganization in the CVS repo, is to declare
> > the current tree dead, and reimport the source in the reorganized
> > layout somewhere new in the repository. You can still get the old
> > information if necessary, but moving files around a cvs repository
> > tends to be a pain.
> This might work. But this is also the time to do a more radical
> cleanup and we can only do that on the development tree.
> Even major source code reorganisation should IMO not done in a beta
> phase of a project.
When I speak of reimporting the source as a new tree, I don't mean
reorganizing the development branch. I mean declare all branches
in the current source base "dead", and create a new cvs module, say
"grass-reorg" (aliased to "grass", of course) that is organized
with everything in the right and proper place. Under that top
level module, could be modules corresponding to the various thematic
packages for ease of making tarball releases. That way, if you
check out "grass", you get everything, but you could still just
check out "grass-base" and "grass-nviz" if that's all you needed.
> Bernhard
-- ebm
| Eric B. Mitchell mailto:emitchell at altaira.com |
| tel: (301) 809 - 3534 Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122 Bowie, MD 20716 |
,___
/"\ / o=\ /"""---===/
/ \_/ \__/ ---===/
| //\ || /""TT""/ //\ || ||""\
| // \ || || // \ || ||__/
| //--==\ |L--/ || //--==\ || || "=,
\____---===/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
