[GRASS5] Thought on my CVS problem
Justin Hickey jhickey at hpcc.nectec.or.th
Tue Sep 12 03:09:46 EDT 2000
Hello all
Yesterday, when I found that some files in the CVS tree that I had not
modified were changed when I did a cvs commit from the top directory, I
thought that such commits were not a good idea. After thinking about
this though, I feel that there should be no reason for not performing a
commit from the top of the CVS tree. After all, the cvs commit command
is recursive by default for a reason - to allow multiple files in
several directories to be committed at the same time.
At the time, I was more concerned with getting the tree back to normal
than with what was actually happening, especially since the first few
files I checked had been wiped out (see this old version
http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass/man/cat1/r.mapcalc?rev=1.5&content-type=text/plain
for an example). But today, I have looked into the files that caused the
problem and the following files can be explained.
src/include/config.h
src/raster/r.binfer/gram.c
src/raster/r.binfer/lex.c
src/raster/r.combine/cmd/gis_lxcl.c
src/raster/r.combine/cmd/gis_pars.c
src/raster/r.combine/cmd/gis_pars.h
src/raster/r.combine/cmd/gis_pars.out
src/raster/r.mapcalc/polish/lex.yy.c
src/raster/r.mapcalc/polish/y.tab.c
src/raster/r.weight/inter/gis_lxcl.c
src/raster/r.weight/inter/gis_pars.c
src/raster/r.weight/inter/gis_pars.h
src/raster/r.weight/inter/gis_pars.out
src/scripts/shells/create_fifos.sh
Correct me if I'm wrong, but all of these files are created at compile
time. As such, I would like to propose that these files be removed from
the CVS source tree. The only ones I hesitate to remove are config.h,
and create_fifos.sh. I think config.h can be removed since it is created
by the configure script, but I'm not sure about create_fifos.sh.
Most of the other files are man pages
man/cat1/r.mapcalc
man/cat1/r.patch
man/cat3/v.in.dxf3d.sh
man/cat4/m.ipf
man/cat4/m.sdts.read
man/cat4/m.svfit
man/cat4/v.out.sdts
man/cat4/v.sdts.dq.cp
man/cat4/v.sdts.meta
man/cat4/v.sdts.meta.cp
man/cat4/v.what
man/utilities/man.version
I don't know why these files were changed. But upon investigation,
perhaps all the files in the cat directories should be removed from the
CVS source tree since the man/utilities/Nroff script supposedly creates
them at compile time (from the Nroff script: "Script to produce cat*
entries from GRASS man* man page source.") as well as the man.version
file. Maybe even the cat directories thenmselves should be deleted and
their creation added to the src/CMD/generic/GISGEN.sh script similar to
the man/1, man/2 etc. directories.
Since it appears that these files are all created during compilation,
then performing a cvs commit at the top of the CVS source tree should
not be a problem.
Anyway, does anyone know of any reason why these files should not be
removed from the CVS source tree? Since Markus is away this week, I will
wait to hear from him before I do anything. But, at this time I see no
reason to keep files that are generated at compile time in the CVS
source tree.
By the way, if these files are removed from the source tree, I will add
them to the "make distclean" target in the Makefile.in file as well.
Thank you for your time and any comments would be greatly appreciated.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
