[GRASS5] Cygwin build of Grass5
Mike Thomas mthomas at gil.com.au
Fri Sep 8 18:21:24 EDT 2000
Hi Markus.
> please don't give up! :-) I suggest you put all your comments into
> a file "windows_dll.txt" and store it in CVS in
> /documents/windows_dll.txt
> I would be glad if your comments are stored there. If required
> I can put this file into CVS for you.
> Probably we add another file: "new_code_structure.txt" or similar?
Sounds good.  I'm trying to avioid the computer for a week due to neck
problems so I'll do it then.
> Yours
>  Markus
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
