[GRASS5] r.null bug or gis library bug?
Markus Neteler
neteler at geog.uni-hannover.de
Fri Sep 8 09:28:38 EDT 2000
On Fri, Sep 08, 2000 at 05:18:58AM +0900, GRASS wrote:
> hi all,
> r.null has bug:
> r.mapcalc "tmp=2.0"
> r.null map=tmp setnull=2.0
> Floating exception error occurred.
Hi Huidae Cho,
on my Linux box there is no floating point exception.
> 1. Size of f_range file changes to zero while running r.null.
Yes, here, too:
ls -la $LOCATION/cell_misc/tmp/
insgesamt 10
drwxr-xr-x 2 neteler user 1024 Sep 8 14:30 .
drwxr-xr-x 26 neteler user 1024 Sep 8 14:30 ..
-rw-r--r-- 1 neteler user 52 Sep 8 14:30 f_format
-rw-r--r-- 1 neteler user 5 Sep 8 14:30 f_quant
-rw-r--r-- 1 neteler user 0 Sep 8 14:30 f_range
-rw-r--r-- 1 neteler user 5712 Sep 8 14:30 null
> 2. G_number_of_cats() called on line 316 in src/raster/r.null/null.c
> 3. G_read_range() called on line 395 in src/libes/gis/cats.c
> 4. G_read_fp_range() called on line 209 in src/libes/gis/range.c
> 5. returns 2 on line 156 in src/libes/gis/range.c
> because f_range size is 0.
> 6. G_get_fp_range_min_max() set drange->min, drange->max to NULL
> as drange->first_time == 1
> 7. Now, trying to assign double NULL value(means NaN) to integer var.
> ==> BUG
Yes, this looks like a bug (at least to me).
Yours
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
