[GRASS5] r.in.gdal available
Markus Neteler
neteler at geog.uni-hannover.de
Thu Sep 7 15:01:53 EDT 2000
Frank Warmerdam wrote:
>I have written a preliminary implementation of r.in.gdal, and have
>provided it to someone to tryout. This is a grass command that load
>libgdal.1.1.so and uses it to import any GDAL supported raster formats,
>floating point or integer. You can find the source, and a bit of info at:
> http://gdal.velocet.ca/projects/grass/
>From his page:
>This is a raster import program based on my Geospatial Data Abstraction
>Library (GDAL). It supports import of a wide variety of
>raster file formats, including many variations on GeoTIFF.
>The current implementation uses dynamic loading of libgdal.1.1.so using
>dlopen(), so as to avoid depending on linking against
>GDAL explicitly. Integer and floating point rasters are supported; as well
>as importing the georeferenced bounds. However, the
>projection defaults to the current mapset projection, and category lists and
>color tables are not yet supported. I am interested in
>ongoing feedback on r.in.gdal and hope to incorporate it into the master
>GRASS CVS tree by the end of October/2000.
http://www.remotesensing.org/gdal/
FYI...
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
