[GRASS5] Driver Update
Justin Hickey
jhickey at hpcc.nectec.or.th
Mon Apr 30 07:04:27 EDT 2001
Hi Glynn
Glynn Clements wrote:
> Can you tell me roughly what sort of time intervals are involved
> here?
> The first call to Do_work(1) should immediately follow
> get_connection_sock(). The next call will occur after the first
> command is read and processed.
Both calls to Do_work(1) seem to occur immediately.
> The client should print the warning after 5 seconds, and the error
> after a further 10 seconds.
Yep, these times are the times I get.
> The fact that Do_work(1) gets called a second time suggests that all
> of the data has been sent. Or, at least, the driver isn't blocking
> trying to send it. I've commited an update to
> src/display/devices/lib/command.c which checks the return value from
> the write() call, in case that's failing for some reason.
Are you sure you committed the change? I updated the file and CVS
reported it as an M update which means the differences are from my local
file. So I looked through the file but did not see any changes for the
write() command. Just curious.
> > Monitor: read1: n_read = 0
> > get_command was != 0
> This is to be expected; at this point, the client has given up and
> closed the connection.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
