[GRASS5] Driver Update
Justin Hickey jhickey at hpcc.nectec.or.th
Mon Apr 30 05:05:52 EDT 2001
Hi Glynn
Glynn Clements wrote:
>   We previously established that get_command() is returning non-zero.
>   If you're not getting the "Premature EOF" message from
>   get_command(), then the first read1(c) in get_command() must be
>   returning non-zero.
>   If you're not getting the "Error reading input" message from
>   read1(), then the read() call in read1() must be returning zero,
>   indicating EOF from the client. Can you add a "if (n_read == 0)
>   printf(...)" to read1() just to confirm this beyond doubt?
Yes I believe this is correct, here is the output for your reference
after an update about 6 hours ago.
using default visual which is TrueColor
Visual is read-only or using a private colormap
ncolors: 32768
allocating memory...
About to call prepare_connection_sock
About to call get_connection_sock
Graphics driver [x0] started
About to call Do-work (0)
About to call Do-work (1)
Warning - no response from graphics monitor <x0>.
Check to see if the mouse is still active.
ERROR - no response from graphics monitor <x0>.
Monitor: read1: n_read = 0
get_command was != 0
About to call close(_wfd)
Problem selecting x0. Will try once more
Sorry to be such a pain and not much use to you. I just don't have time
to become familiar with the source code.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
