[GRASS5] g.gnuplot
Glynn Clements
glynn.clements at virgin.net
Fri Apr 27 18:11:53 EDT 2001
> > > > Would it be possible to specify the program to use, similar to $EDITOR or
> > > > $VISUAL?
> > > That shouldn't take much work; I'll get onto it once CVS is back up.
> > Thanks, Glynn. Just let us know -- in the documentation -- what variable
> > name you've chosen.
> .. and please add to
> documents/envVars.txt
OK; m.svfit, s.probplt and s.sv all use $GRASS_GNUPLOT as the plotting
program. GRASS_GNUPLOT defaults to "gnuplot -persist" (in
etc/Init.sh).
They no longer check whether the driver is running (not necessary),
and so they don't link to libraster.
I've updated documents/envVars.txt. The programs' HTML files all
mention GRASS_GNUPLOT in the NOTES section.
Also, I've removed all references to g.gnuplot from all HTML files,
and removed g.gnuplot.html.
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
