[GRASS5] Re: [GRASSLIST:1775] r.in.bin
Glynn Clements glynn.clements at virgin.net
Fri Apr 27 14:48:13 EDT 2001
I wrote:
> If I import it into an x-y location, I seem to get the behaviour which
> you describe. OTOH, If I import it into the appropriate lat-lon
> location, I don't have any problems (the only areas with negative
> altitude are where I would expect, i.e. Holland).
Scratch that; I've just re-done it and now I get the problem
regardless of they coordinate system.
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
