[GRASS5] Re: [GRASSLIST:1775] r.in.bin
Glynn Clements glynn.clements at virgin.net
Fri Apr 27 15:52:53 EDT 2001
Jan-Oliver Wagner wrote:
> > I have just been duplicating the error you mention above.  The problem
> > seems to be in the auto calculation of rows cols etc.
> > For a test leave the rows and cols off of the command line, and see if
> > your data is imported. The program will report the calculated rows and
> > columns which will hopefully be the same as above.
> I tried this already, but it did not work (default rows was 50).
Yep; you need to be able to specify all of the parameters if the image
resolution doesn't match the location's resolution.
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
