[GRASS5] Re: [GRASSLIST:1775] r.in.bin
Markus Neteler neteler at geog.uni-hannover.de
Fri Apr 27 04:43:00 EDT 2001
On Thu, Apr 26, 2001 at 10:45:37PM +0100, Glynn Clements wrote:
> Yan Fitterer wrote:
> > First, congratulations for a briliant program.
> > My problem (is it a bug?):
> > I'm getting a gtopo30 file from:
> > http://edcdaac.usgs.gov/gtopo30/w020n90.html
> > The I try to import the .DEM file into Grass with r.in.bin
> > I get all OK (byte swap, signed integer, etc...) except that at a level of
> > about 110 (going up a hill for ex.), the z (altitude) values suddently go to
> > -120, and then increase in line with the terrain.
> > Has anybody seen that behaviour?
> > I'm running 5.0 beta 11 on Linux RH 7.0 (2.2.16 kernel)
> I get conflicting results.
> If I import it into an x-y location, I seem to get the behaviour which
> you describe. OTOH, If I import it into the appropriate lat-lon
> location, I don't have any problems (the only areas with negative
> altitude are where I would expect, i.e. Holland).
> NB: I'm running the latest 5.0 CVS, and there's a bug where it ignores
> the rows/cols parameters if you specify N/E/S/W (I've fixed this, but
> CVS is down right now so I can't commit it).
Glynn,
Bob did much mork on r.in.bin, I think he will respond later this day (after
getting up in Canada). Before commiting your bugfix:
The idea was that you can import (AVHRR, xy) data by simply entering rows and
cols. It would be nice if your fix could keep this feature.
Just a remark,
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
