[GRASS5] Re: [GRASSLIST:1775] r.in.bin
Glynn Clements glynn.clements at virgin.net
Thu Apr 26 17:45:37 EDT 2001
Yan Fitterer wrote:
> First, congratulations for a briliant program.
> My problem (is it a bug?):
> I'm getting a gtopo30 file from:
> http://edcdaac.usgs.gov/gtopo30/w020n90.html
> The I try to import the .DEM file into Grass with r.in.bin
> I get all OK (byte swap, signed integer, etc...) except that at a level of
> about 110 (going up a hill for ex.), the z (altitude) values suddently go to
> -120, and then increase in line with the terrain.
> Has anybody seen that behaviour?
> I'm running 5.0 beta 11 on Linux RH 7.0 (2.2.16 kernel)
I get conflicting results.
If I import it into an x-y location, I seem to get the behaviour which
you describe. OTOH, If I import it into the appropriate lat-lon
location, I don't have any problems (the only areas with negative
altitude are where I would expect, i.e. Holland).
NB: I'm running the latest 5.0 CVS, and there's a bug where it ignores
the rows/cols parameters if you specify N/E/S/W (I've fixed this, but
CVS is down right now so I can't commit it).
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
