[GRASS5] 5.0.0pre1 on mac osx - related tk make problem
Malcolm Blue
mblue at nb.sympatico.ca
Thu Apr 26 17:08:54 EDT 2001
Andy,
This is the same problem. I took a quick look at the version that I compiled
(8.0.5) and the Makefile had a variable called CFLAGS_DEBUG defined as -g. It
didn't appear to be used in the make that I did, but it may in your version. If
removing the -g from the COMPILE_FLAGS in the head file works for the XDRIVER,
then you can check the makefile for tk, and remove the '-g' there.
Other than that, I can only suggest trying to get new X libraries. Is your setup
different than what Jeshua used? I'm not at all familiar with Mac OS X.
Malcolm
andy agena wrote:
> Hi Malcolm:
> I finally got a hold of the tcl/tk (8.3.2) source code. tcl installed
> without a hitch. tk had a make error that seems related to my grass
> problem:
> usr/bin/ld: Undefined symbols:
> __XErrorFunction
> __XIOErrorFunction
> __Xdebug
> make: *** [wish] Error 1
> Andy
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
