[GRASS5] 5.0.0pre1 on mac osx
andy agena
andya at mac.com
Thu Apr 26 00:47:59 EDT 2001
Hi Malcom:
> Sorry. I wasn't clear here. In /usr/X11R6/include you should do 'grep
> ErrorFunction *.h' This should find out if the ErrorFunction symbols
> are
> redefined. Also, do 'grep Xdebug *.h'.
[localhost:X11r6/include/x11] root# grep ErrorFunction *.h
Xlibint.h:extern int (*_XIOErrorFunction)(
Xlibint.h:extern int (*_XErrorFunction)(
[localhost:X11r6/include/x11] root# grep Xdebug *.h
Xlib.h:#define _Xdebug (*_Xdebug_p)
Xlib.h:extern int _Xdebug;
> These results seem strange. The symbols that ld can't find should be
> coming from
> here. The XDRIVER code doesn't call these routines, or define the
> variables, so
> they must be in the header files in /usr/X11R6/include and in libraries
> that are
> being used. Hopefully the grep (above) will find out how they are
> declared.
> These symbols should be in libX11.a, but perhaps they are defined
> differently
> through the include files. I was expecting to see that they only had
> one leading
> underscore, rather than 2. We can do the same thing a different way.
> Check to see if your system has the nm utility. Do 'nm -s libX11.a'.
> This
> should produce a lot of output on the symbols. To use this, I pipe to
> less like
> 'nm -s libX11.a | less'. Then you can find the string, using the find
> operator in
> less (/). Once in less do '/ErrorFunction'. This should find the
> __XIOErrorFunction and __XErrorFunction symbols. Or you can pipe to
> grep like
> 'nm -s libX11.a | grep ErrorFunction'.
> You can do the same thing with libXext.a.
my nm wants:
Usage: nm [-agnoprumxjl[s segname sectname] [-] [[-arch
<arch_flag>] ...] [file ...]
and I wasn't sure what i need to put in for "setname sectname" so I just
used -a:
[localhost:/usr/x11r6/lib] root# nm -a libX11.a | grep ErrorFuntion
nm: no name list
nm: no name list
nm: no name list
[localhost:/usr/x11r6/lib] root# nm -a libXext.a | grep ErrorFunction
00000004 C __XExtensionErrorFunction
U __XExtensionErrorFunction
> Tiff and png are probably OK, but to be safe, you could add
> -I/usr/local/include
> to the include files (INC or INCPATH) and -L/usr/local/lib to the
> library lines
> (LIB and LIBPATH), like this:
> #Image formats:
> PNGINC = -I/usr/local/include -I/usr/include
> PNGLIB = -L/usr/local/lib -L/usr/lib
> TIFFINCPATH = -I/usr/local/include
> TIFFLIBPATH = -L/usr/local/lib
> Check to see that the header files are in /usr/local/include. You
> should find
> tiff.h and png.h there, these are the include (or header) files. Once
> you get
> the *.h files from Jeshua, you can do the same for the TCL/TK lines.
Jeshua can't get to his *.h for a few days, so I'm trying to find the
tcl/tk source, and one of pages I found
<http://dev.scriptics.com/software/tcltk/downloadnow83.html> keeps
timing out when I attempt to download.
> Did the tcltkgrass menu's start up here? This should start the GUI.
> You will
> know when it starts.
tcltkgrass did start here--and at times I can be an idiot: I didn't
even see the menu until I maximized my vnc window.
Thanks,
Andy
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
