[GRASS5] Driver Update
Justin Hickey
jhickey at hpcc.nectec.or.th
Wed Apr 25 04:39:34 EDT 2001
Glynn Clements wrote:
> Justin Hickey wrote:
> > > Do you have strace() or similar?
> > Hmmpf. It figures that strace on SGI is different from Linux. The
> > best I can do here is provide you with a system call trace, but I
> > don't know if that will be useful to you. Please let me know if you
> > want it anyway.
> Yes; for the XDRIVER process (I'm fairly sure that the client side is
> OK).
Hmmm. To get a trace I need to pass a command line to the trace program.
I think
par d.mon start=x0
will trace the client. How do I trace the XDRIVER?
> > using default visual which is TrueColor
> > Visual is read-only or using a private colormap
> > ncolors: 32768
> > allocating memory...
> > About to call prepare_connection_sock
> > About to call get_connection_sock
> > Graphics driver [x0] started
> > About to call Do-work (0)
> > About to call Do-work (1)
> This implies the connection has been accepted.
> This seems to suggest that it has successfully read and processed one
> command.
> > // Slight pause here
> > Warning - no response from graphics monitor <x0>.
> > Check to see if the mouse is still active.
> > ERROR - no response from graphics monitor <x0>.
> > About to call close(_wfd)
> Uh Oh. Something caused the command loop to terminate; the latest
> version of lib/main.c prints an error message if an abnormal
> termination occurs. It would be useful to know which of the three
> possible cases occurred. The choices are:
> if (setjmp(save))
> Indicates that SIGPIPE was caught (write to broken pipe).
> if (get_command(&c) != 0)
> Driver got EOF while expecting command; this the "normal" case.
> if (process_command(c))
> Driver got EOF while expecting command parameters/data.
I'm using your new code with the fprintf()'s so since nothing was
printed it must be the get_command() function. ... wait ... Just checked
to be sure and yep it's the get_command() function.
I also noted that the "while(1)" loop has no way of exiting if that
means anything ie. the main function never returns. I'm not sure if that
means anything.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
