[GRASS5] Driver Update
Justin Hickey
jhickey at hpcc.nectec.or.th
Mon Apr 23 01:05:29 EDT 2001
Hi Glynn
I just tried a fresh checkout of the release branch and there are
problems running d.mon on an SGI using SGI compilers.
The monitor window will pop up but I get the following output:
GRASS 5.0.0pre1 > d.mon start=x1
using default visual which is TrueColor
Visual is read-only or using a private colormap
ncolors: 32768
allocating memory...
Graphics driver [x1] started
Warning - no response from graphics monitor <x1>.
Check to see if the mouse is still active.
ERROR - no response from graphics monitor <x1>.
Problem selecting x1. Will try once more
Also, even after the command quits, there are delays in mouse response
until I closed the monitor window using the window manager (click the
close button on the window). I'm not sure what is causing these delays.
I'm sorry but I don't have time to investigate this.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
