[GRASS5] Again Solaris/tar/Makefile problem
Glynn Clements
glynn.clements at virgin.net
Mon Apr 23 02:55:29 EDT 2001
Justin Hickey wrote:
> > > one of the problems on Solaris tar is that options MUST go
> > > first (and i think it depends on getopt in the libraries which
> > > behaves strangely). I installed Grass on a solaris, and solved the
> > > tar problem that way (just moved options at the beginning).
> > Huh? The options are at the beginning:
> > ${SHELL} -c "cd ${GISBASE} ; tar cBf - bin/ | (cd ${INST_DIR}
> > ; tar xBf - ) 2>/dev/null ; true"
> > We're not using the newer "dash" form (switches preceded with dashes,
> > with arguments immediately following the corresponding switch).
> Has this been solved yet? I just don't want this to be ignored again.
Nothing has changed yet. I think that the relevant issue is a few
messages back:
> Is it not safe to simply omit the trailing slash?
Unless someone actually says "no, FooOS complains if you omit the
trailing slash", I suggest that we remove it.
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
