[GRASS5] Driver Update
Malcolm Blue
mblue at nb.sympatico.ca
Sun Apr 22 08:28:42 EDT 2001
Glynn,
Sorry, it wasn't your code change that was causing the problem. It was my system.
XDRIVER was crashing because of some testing I was doing to get postgresql running. I
reversed the cygwin system changes I had made, did a cold reboot and the grass monitor
runs.
I'll do some more testing now. So far, I've just verified that a few of the display
commands work on the XDRIVER (d.vect, d.rast and d.site).
Malcolm
Malcolm Blue wrote:
> Glynn,
> First, I can tell you that it is the XDRIVER program that is crashing. Second, it
> seems to be in the initial communication from the select command.
> Also, I had created a whole new grass directory structure, so there is no conflict of
> old and new programs or libs.
> So far I've determined that the problem is in
> R_open_driver() in select.c,
> sync_driver() in io.c,
> read() call in sync_driver().
> I had tested the reverse of your suggestion. I tried the old XDRIVER executable with
> the new build. That had the same result as before, so I thought it was in io.c. That's
> why I tracked the problem down to the first read() in the sync function. So after
> that, I started looking for mismatches between the routines. I haven't found any.
> After reading your response, I tried replacing io.c and rebuilding rasterlib &
> mon.select. That had the same result as before.
> The monitor (XDRIVER) is running until I do the select with any of these combinations.
> Were there other changes that I can look at? Did you change any of the sockets calls,
> or just where thay are called from?
> I'm also going to reinstall my lat bindist to make sure that this isn't something I've
> caused separately from your fixes.
> Malcolm
> Hopefully we'll know soon.
> Thanks,
> Malcolm
> Glynn Clements wrote:
> > Malcolm Blue wrote:
> > > On first try with the new drivers on Cygwin, I get an access violation during
> > > "d.mon x0" or "d.mon select=x0". The monitor starts if I do "d.mon -s start=x0",
> > > but then crashes on "d.mon select=x0".
> > Is there anything to indicate whether it's the monitor (XDRIVER) or
> > d.mon/mon.select that's crashing?
> > > In my initial look at the code, I noticed that for libes/raster/io.c outbuf was
> > > defined as 2048 (BUFFERSIZ), while in display/devices/lib/connect.c inbuf is set
> > > to 4096. I changed inbuf to 2048 and recompiled in display/devices/lib and
> > > display/devices/XDRIVER, but still got the same error.
> > > I'll look a little more to see if I can see where the error is coming from (but
> > > debugging on Cygwin is tedious at best - and only for console apps). From my
> > > experience, access violations come from initialized variables or array/struct
> > > overflows. Any idea where I should look first?
> > The first thing is to determine which program is crashing.
> > If it's mon.select, try checking out the old version of
> > src/libes/raster/io.c (use the "devices_cleanup_20000420" tag). If
> > that fixes it, the problem lies there. If it doesn't, or if it's
> > XDRIVER which is crashing, there are more files to consider.
> > A couple of questions: First, did you delete the old driverlib.a
> > libraries? Just doing "cvs update ; make" will have problems. Second,
> > were there any warnings relating to src/display/devices/*?
> > Glynn Clements <glynn.clements at virgin.net>
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
