[GRASS5] testing GRASS5.0.0pre1
mberglund
matt at rcinfo.net
Fri Apr 20 11:30:28 EDT 2001
Ok, the test results are in.
Test 1:
Fri Apr 20 09:37:05 EDT 2001
r.patch: percent complete: 100%
CREATING SUPPORT FILES FOR testpatch
Fri Apr 20 09:39:36 EDT 2001
Test 2:
g.region res=1 -p
nsres: 1
ewres: 1
rows: 20000
cols: 20000
GRASS:~ > date; r.mapcalc testA="if(row()%2., row(), null())"; date
Fri Apr 20 09:44:40 EDT 2001
EXECUTING testA = ... 100%
CREATING SUPPORT FILES FOR testA
range: 1 19999
Fri Apr 20 10:04:48 EDT 2001
GRASS:~ > date; r.mapcalc testB="if(row()%2., row(), null())"; date
Fri Apr 20 10:06:15 EDT 2001
EXECUTING testB = ... 100%
CREATING SUPPORT FILES FOR testB
range: 1 19999
Fri Apr 20 10:29:08 EDT 2001
Fri Apr 20 10:33:34 EDT 2001
Fri Apr 20 11:05:47 EDT 2001
Well, there you go. I am not sure what this proves. But what I do believe
is the color issue is hurting me. for the area covered, the times seem
reasonable.
Does this mean grass is not well suited to my application (patching lots
of images over a large area) or does this mean that I am doing something
wrong with the images?
I am glad r.patch works, now I need to figure out how to achieve my goal.
Any advise or ideas would be useful.
Thanks again,
Matt
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
