[GRASS5] testing GRASS5.0.0pre1
Markus Neteler
neteler at geog.uni-hannover.de
Fri Apr 20 11:42:28 EDT 2001
On Fri, Apr 20, 2001 at 10:07:51AM -0400, mberglund wrote:
> But in the patch I had a 830KB cat file! The color file was also large.
Mhhh, the color/cat patch seems to be poor in r.patch (therefore we
have i.image.mosaik as a workaround). It should become better once...
> > Perhaps above test should be extended with some r.colors stuff to assign
> > more colors (to get a larger color table). Note: It is well known that
> > GRASS becomes *very* slow with more than 8000 entries in color table.
> Is grass also slow to create the colors? And does it stand to reason that
> a larger number of categories implys a larger color palete.
I guess it is a color sort problem or so.
Have a look here on former threads:
http://www.geog.uni-hannover.de/mailinglisten/grass5/archive/2001/3/24/2
http://www.geog.uni-hannover.de/mailinglisten/grass5/archive/2001/3/9/11
http://www.geog.uni-hannover.de/cgi-bin/minorweb.pl?A=READ&L=grass5/2001/3/8/24
http://www.geog.uni-hannover.de/cgi-bin/minorweb.pl?A=READ&L=grass5/2001/3/9/4
If you look at r.in.tiff you will see some logic to reduce colors.
Maybe you can dig into all this?
Thanks,
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
