[GRASS5] Volunteer wanted for CELL driver color problem
Andreas Lange Andreas.Lange at Rhein-Main.de
Thu Apr 19 17:38:34 EDT 2001
Hi Glynn,
your plans are great. I once started to look into a major cleanup of the
code, but had no time and no motivation.
The #ifndef __CYGWIN__ directives should be removed.
I don't think anyone is using the IPC version. So it can be safely
removed.
cu,
Andreas
Glynn Clements wrote:
> My plan is to:
> a) Remove all of the debug code. The (presumably) most heavily used
> version (XDRIVER24/socket.new) seems to live without it. And gdb is
> free.
> b) Remove the "#ifdef ORIG" code; three out of four versions seem OK
> without it.
> c) Remove the "#ifndef __CYGWIN__" around the FONT and TEXT cases. The
> socket versions seem OK without it.
> d) Create {check,get}_connection() for the socket version.
> e) Remove the myriad versions of connect.c and just leave the one in
> devices/lib.
> f) Define USE_G_FIFO/USE_G_IPC analogous to USE_G_SOCKS. Use these to
> conditionalise code and, ultimately, eliminate README.xdriver.
> g) I'm going to leave src/libes/raster/io.c until later.
> Any objections?
> BTW, is anyone actually using the IPC version? Or, for that matter, is
> anything other than the socket version getting tested regularly?
> Glynn Clements <glynn.clements at virgin.net>
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
