[GRASS5] Volunteer wanted for CELL driver color problem
Glynn Clements
glynn.clements at virgin.net
Thu Apr 19 13:15:03 EDT 2001
Markus Neteler wrote:
> GRASS:~ > d.mon CELL
> Graphics driver [CELL] started
> Wait for 'READY'
> Socket is already in use or not accepting connections.
> Use d.mon to select a monitor
> Problem selecting CELL. Will try once more
> READY
> -> I had included your proposed "sleep(1)" in d.mon/cmd/main.c
> Probably we should distinguish between CELL start (with sleep) and XDRIVER
> start (without sleep). I have a 1GHz Athlon board here.
Ideally d.mon would retry the select until success or timeout (at
least in the auto-select case).
> However, I think Glynn is looking into this as well now for a cleanup.
Yep; having compared the fifo.orig/sockets.new versions of SWITCHER.c
(in both devices/lib and devices/XDRIVER/XDRIVER24), there are a
number of differences which have nothing to do with FIFO/socket
differences. Specifically:
1. XDRIVER24/socket.new version has debug code removed.
2. XDRIVER24/fifo.orig version has "#ifdef ORIG" code; the other three
don't.
3. Both fifo.orig versions have "#ifndef __CYGWIN__" around the FONT
and TEXT cases; the socket.new versions don't.
4. Various minor differences which seem equally applicable to all
versions, but presumably only went into whichever version the author
was using/considering at the time. This includes my warning
elimination patches, which were only made to the files which were
actually listed in compile_warnings.log.
Also, the fifo.orig versions have the {check,get}_connection()
functions in connect.c, whilst the socket.new versions inline the
equivalent code.
There are two versions of XDRIVER/lib/connect.c (the socket.new
version being empty), but not of lib/connect.c, CELL/connect.c,
HTMLMAP/connect.c or PNGdriver/connect.c.
Furthermore, all of the various connect.c files are almost identical,
which is as I would expect; how to transport the data and what to do
with it are orthogonal. The differences appear to be "fixes" which
only made it into one version or another.
My plan is to:
a) Remove all of the debug code. The (presumably) most heavily used
version (XDRIVER24/socket.new) seems to live without it. And gdb is
free.
b) Remove the "#ifdef ORIG" code; three out of four versions seem OK
without it.
c) Remove the "#ifndef __CYGWIN__" around the FONT and TEXT cases. The
socket versions seem OK without it.
d) Create {check,get}_connection() for the socket version.
e) Remove the myriad versions of connect.c and just leave the one in
devices/lib.
f) Define USE_G_FIFO/USE_G_IPC analogous to USE_G_SOCKS. Use these to
conditionalise code and, ultimately, eliminate README.xdriver.
g) I'm going to leave src/libes/raster/io.c until later.
Any objections?
BTW, is anyone actually using the IPC version? Or, for that matter, is
anything other than the socket version getting tested regularly?
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
