[GRASS5] Cleaning and merging v.in.dxf, v.in.dxf2
Markus Neteler neteler at geog.uni-hannover.de
Thu Apr 19 12:46:38 EDT 2001
On Thu, Apr 19, 2001 at 09:05:42AM +0000, Michel Wurtz wrote:
> Markus Neteler wrote:
> > Perhaps he will update v.in./out.dxf/2 as well,
> > then consistency should be back.
> Ok, I had a look at v.[in|out].dxf{2} :
> I've synchronised v.in.dxf and v.in.dxf2 (merging the
> modifications done in both versions) : Markus, you can
> throw away v.in.dxf2 : v.in.dxf is the updated version
> (I have commited the changes in the current CVS tree)
Thanks, Michel. I have updated the release branch now (as
you wrote into the exp tree) and removed the v.in.dxf2.
> BTW, you can also delete the nps_dxf directory in v.in.dxf :
> it contains old stuff that is no more usefull (put it in
> the attic :-)
O.k., done.
> I looked also v.out.dxf and the actual export sheme is the
> following, with
>   GBVF = Grass Binary Vector File (in $LOCATION/dig...)
>   GAVF = Grass Ascii Vector file (in $LOCATION/dig_ascii)
> GBVF <-- v.in.arc <------------------------------ ESRI ungenerate files
> GBVF --> v.out.arc -----------------------------> ESRI ungenerate files
> GBVF <-- v.in.shape <---------------------------- ESRI shapefile
> GBVF --> v.out.shape ---------------------------> ESRI shapefile
> GBVF <-- m.in.e00 <------------------------------ .e00 ESRI export file
> GBVF --> v.out.e00 -----------------------------> .e00 ESRI export file
> GBVF <-- v.in.mif <------------------------------ mif/mid Mapinfo
> GBVF --> v.out.mapinfo -------------------------> mif/mid Mapinfo
> GBVF <--------------------------- v.in.dxf <----- .dxf file
> GBVF <-- v.in.ascii <--- GABF <-- v.in.dxf -a <-- .dxf file
> GBCF --> v.out.ascii --> GABF --> v.out.dxf ----> .dxf file
> Conclusion :
> 1- The dig_ascii directory seems only usefull for v.out.dxf, which
> should be rewritten to read binary vector files.  After that,
> v.[in|out].ascii should write anywhere (same thing as other import/
> export programs), and act as a general utility.
Here David and Radim may propose a solution.
> 2- v.out.mapinfo should certainly be named v.out.mif for consistency
>   (or v.in.mif renamed v.in.mapinfo)
We have both v.out.mapinfo and v.out.mif. Which one is current and
working (hi David)? We should remove any old version.
> 3- v.in.dlg and v.out.dlg seems to use a DLG directory in $LOCATION
Oh - another candidate... :-)
> 4- I didn't look at v.[in|out].atlas, nor v.in.gshhs, nor v.out.moss
> (is moss output really usefull ?)
I am not sure if v.[in|out].atlas is really working? Does anyone know?
And: shall we keep v.out.moss?
v.in.gshhs should read from the current directory (it uses fopen).
It is in working condition.
Thanks for the update, Michel,
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
