[GRASS5] Volunteer wanted for CELL driver color problem
Markus Neteler
neteler at geog.uni-hannover.de
Thu Apr 19 06:33:24 EDT 2001
On Wed, Apr 18, 2001 at 10:34:30PM +0100, Glynn Clements wrote:
> Andreas Lange wrote:
> > i watched this strange behaviour with my last cygwin/Windows build of
> > the pre-stable code. IMHO it is not the "start" parameter, but d.mon
> > start=CELL works once, but no longer after the CELL driver is stopped
> > with d.mon stop=CELL.
> > I can restart the CELL driver only if i remove the
> > $LOCATION/.tmp/$hostname/CELL socket file. I think for some reason the
> > file/socket is not removed.
> Compare the code in src/display/devices/lib/SWITCHER.c:
> if (G_sock_exists(sockpath) &&
> (listenfd = G_sock_connect(sockpath)) != -1)
> close (listenfd);
> G_fatal_error ("Monitor <%s> is already running", me);
> to that in src/display/devices/XDRIVER/XDRIVER24/SWITCHER.c:
> if (G_sock_exists(sockpath))
> if ((listenfd = G_sock_connect(sockpath)) != -1)
> close (listenfd);
> fprintf (stderr, "Monitor <%s> is already running\n", me);
> exit (EXIT_FAILURE);
> if (unlink (sockpath) != 0)
> fprintf (stderr, "Failed to remove stale socket file:\n"\
> "\t%s\n", sockpath);
> Someone thought to remove the socket if it exists but is unused; but
> only for the XDRIVER case.
> I've been looking through some of the files in src/display/devices
> today, and it's clear that the whole thing needs a spring clean. A lot
> of code is (more or less) duplicated when it ought to be shared, and
> changes only seem to get put into one or other of the different
> versions.
> Rather than just copying the fixes around between the versions, I'm
> going to start moving common code out of the individual drivers and
> back into src/display/devices/lib where it belongs.
Thanks for your offer, Glynn,
it will be great to use your cleaned code. Probably all our problems
disappear then.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
