[GRASS5] Volunteer wanted for CELL driver color problem
Malcolm Blue
mblue at nb.sympatico.ca
Wed Apr 18 16:30:08 EDT 2001
Bob,
It sounds like your CELL driver is the FIFO version, while d.mon is is the
sockets version.
Did you compile this yourself? If so check the source code for SWITCHER.c in
display/devices/lib vs display/devices/lib/sockets.new and
display/devices/lib/fifo.orig (could also check ipc.new). You could also check
in XDRIVER/XDRIVER24. I just checked the file sizes to verify that socket.new is
different size from fifo.orig version. If your monitor works, and the monitor is
using the socket version - which seems likely since that's what d.mon is using,
then you should recompile the devices/lib directory and the CELL driver (at
least). libes/raster/io.c may be worth checking as well.
Depending on what is out of sync you may need to recompile other routines as
well.
HTH,
Malcolm
Bob Covill wrote:
> Hello,
> I am still digging into why the CELL driver won't start. The error
> Usage: CELL [-] "input_fifo output_fifo"
> is generated from SWITCHER.c in src/dsplay/devices/lib.
> I was able to successfully start the CELL driver on an old GRASS5 build
> that used fifos.
> I was able to manually start the CELL driver in the current build with
> the following command:
> $GISBASE/driver/CELL -
> "/DSK4/GRASS_PROG/grass5_beta12/GRASS5/grass5/dev/fifo.8a
> /DSK4/GRASS_PROG/grass5_beta12/GRASS5/grass5/dev/fifo.8a"
> It seems that d.mon is not passing the required arguments to the CELL
> driver (I think).
> Any help would be appreciated.
> Bob Covill
> Tekmap Consulting
> P.O. Box 2016 Fall River, N.S.
> B2T 1K6
> Canada
> E-Mail: bcovill at tekmap.ns.ca
> Phone: 902-860-1496
> Fax: 902-860-1498
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
