[GRASS5] regex routines
Glynn Clements glynn.clements at virgin.net
Wed Apr 18 12:32:40 EDT 2001
David D Gray wrote:
> One of the shortfalls in writing parsing routines I've found recently is
> that there is no native regex handling stuff in GRASS. (is there?).
Do the regexps need to be constructed at run-time? If not, I would
have thought that it would be better to write the parser using (f)lex.
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
