[GRASS5] Volunteer wanted for CELL driver color problem
Bob Covill bcovill at tekmap.ns.ca
Wed Apr 18 12:50:41 EDT 2001
Hello,
I am still digging into why the CELL driver won't start. The error
Usage:  CELL [-] "input_fifo output_fifo"
is generated from SWITCHER.c in src/dsplay/devices/lib.
I was able to successfully start the CELL driver on an old GRASS5 build
that used fifos.
I was able to manually start the CELL driver in the current build with
the following command:
$GISBASE/driver/CELL -
"/DSK4/GRASS_PROG/grass5_beta12/GRASS5/grass5/dev/fifo.8a
/DSK4/GRASS_PROG/grass5_beta12/GRASS5/grass5/dev/fifo.8a"
It seems that d.mon is not passing the required arguments to the CELL
driver (I think).
Any help would be appreciated.
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
