[GRASS5] Volunteer wanted for CELL driver color problem
Bob Covill
bcovill at tekmap.ns.ca
Wed Apr 18 09:42:38 EDT 2001
Markus Neteler wrote:
> Bob, Eric,
> On Wed, Apr 18, 2001 at 10:23:18AM -0300, Bob Covill wrote:
> > Markus,
> > It has been a long time since I have used the CELL driver, but I decided
> > to take a look at it for investigating the color problem.
> > Unfortunately I got off to a bad start. When I execute d.mon start=CELL
> > I get the following error maessage:
> > Usage: CELL [-] "input_fifo output_fifo"
> > No socket to connect to for monitor <CELL>.
> > Problem selecting CELL. Will try once more
> > The CELL driver has been built and installed.
> > Any idea why it will not start, socket / fifo problem ??
> This is strange:
> GRASS:~ > d.mon CELL
> Graphics driver [CELL] started
> Wait for 'READY'
> READY
> GRASS:~ > d.mon stop=CELL
> Monitor 'CELL' terminated
> GRASS:~ > d.mon start=CELL
> Can't bind to socket for monitor <CELL>. Already in use?
> Socket is already in use or not accepting connections.
> Use d.mon to select a monitor
> Obviously the start= parameter confuses d.mon. Without it works.
> Maybe again the timing story?
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Markus,
I tried ...
d.mon CELL
and got the same error message.
The error you reported above does sound like the timing issue. Try ...
d.mon -s start=CELL
followed by ...
d.mon select=CELL
to see if that helps.
The error that I am getting is on my Solaris machine. I try my Linux
machine a little later and see if the same problem exists there, trying
to start the CELL driver.
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
